Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
FUSION360 UPDATE ISSUES !!!
4 REPLIES 4
ChristophUnbescheidt
432 Views, 4 Replies
I rencently downloaded the new Fusion360 Version ( 01.2016) and wanted to install it but there is an Error on OSX saying....
Industrial Designer
c.unbescheidt@gmail.com
4 REPLIES 4
Can you share with us the installation log file? The below link provides insturctions for how to obtain the log file.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Una...
A quick solution may be to do a clean unisntall and then download a fresh installer.
Clean Uninstall Instructions
Download the installer from the below URL by selecting download free trial.
http://www.autodesk.com/products/fusion-360/overview
I hope this helps.
Nathan Chandler
Principal Specialist
keqingsong
in reply to: innovatenate
@innovatenate it sounds like @ChristophUnbescheidt got it solved as noted in this thread: http://forums.autodesk.com/t5/design-validate-document/january-23-2016-update-is-available/td-p/6003...
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
sanjay_jayabal
in reply to: keqingsong
Hi Christoph,
As Keqing noted, are you past the update issue now?  If you are still having issues, I would like to understand what it is and see if I can have someone from my team help you out.
best regards,
Sanjay Jayabal.
Hey guys !
forgot to keep you updated that 2 hours after my post everything worked out.
think it was a problem wiht uploadig a fil ^^
I love the upadte !
Industrial Designer
