I rencently downloaded the new Fusion360 Version ( 01.2016) and wanted to install it but there is an Error on OSX saying....
Can you share with us the installation log file? The below link provides insturctions for how to obtain the log file.
A quick solution may be to do a clean unisntall and then download a fresh installer.
Download the installer from the below URL by selecting download free trial.
http://www.autodesk.com/products/fusion-360/overview
I hope this helps.
I hope this helps.
@innovatenate it sounds like @ChristophUnbescheidt got it solved as noted in this thread: http://forums.autodesk.com/t5/design-validate-document/january-23-2016-update-is-available/td-p/6003...
Hi Christoph,
As Keqing noted, are you past the update issue now? If you are still having issues, I would like to understand what it is and see if I can have someone from my team help you out.
best regards,
Sanjay Jayabal.
Hi Christoph,
best regards,
Sanjay Jayabal.
Hey guys !
forgot to keep you updated that 2 hours after my post everything worked out.
think it was a problem wiht uploadig a fil ^^
I love the upadte !
Hey guys !
I love the upadte !
