Fusion360 Offset Plane Locates at a location other that the selected location
ecnels
ecnels
When attempting to add an Offset Plane at an Object Location instead of a distance, the resulting Offset Plane locates far away from the chosen Object (in this case a point).  See Screencast.  This looks like a bug, but if I'm just doing something wrong, I'm all ears!
Best Regards
Accepted solutions (3)
jhackney1972
I can confirm that if you are creating an offset plane, using the "To Object" option, between two different components, it does not work as @ecnels states.  The function will work correctly if you are creating an offset plane within the same component. Please see screencast.
John Hackney, Retired
ecnels
Thanks for your refinement on this Issue, i.e. it doesn't work between two different components, but does work in the same component!
jeff_strater
thanks, @ecnels for reporting this and @jhackney1972 for clarifying it.  I can replicate this problem and will submit a bug on it.
bug is:  FUS-47003
Jeff Strater
Engineering Director
