conversion of file types.
Message 1 of 10
I am a novice trying to convert an obj file to a step file. my slow laptop 8mb ram has been chigging along for days and in task manager I can see the software working, but how do I know how far along in conversion process I am if at all?
many thanks in advance, Oliver.
Replies (9)
Message 2 of 10
TrippyLighting
.obj and .stp are not necessarily compatible as both usually contain different types of geometry.
.obj usually contains meshes, most common quad meshes. But is can also contain. triangulated mesh.
,.stp usually contains solid geometry.
If you can share more information about the .obj file or if you can share the file (zip and attach) we can look into it further.
Message 3 of 10
Hello Peter,
Thanks for the response to my problem.
I can send you the file as they are confidential.
Can I go through a conversion to a different file type and then to STEP?
Any ideas on how I monitor the progress of the conversion I am currently running (for the last 3 days), or is Fusion 360 just twiddling its thumbs?
Many thanks, Oliver.
Message 4 of 10
TrippyLighting
The problem is not the filetype, or file extension. The problem is the data they contain.
.obj is a mesh file and .stp is usually a solid model. Both are different mathematical representations and they are not necessarily compatible.
The first thing you need to find out is I that .obj file is a triangulated mesh, or a quad mesh.
Then we need to know the number of polygons involved.
Is this  prismatic or more mechanical geometry , or is it more organic and regular ?
Message 5 of 10
Hi Peter,
OBJ FILE detail triangles 6311959.
What next? Oliver.
Message 6 of 10
TrippyLighting
That sounds like scanned  geometry ?
You failed to answer an essential question:
What is it you want to do with the .stp file ?
The likelihood that you can go through a direct conversion from a mesh to a BRep and then do something with particularly in Fusion 360 is pretty small to say the least!
Based on your answer to the question I repeated, I might be able  suggest workflows, but this is not simple stuff.
Message 7 of 10
Hi Peter,
Your correct it is scanned geometry.
I thought you might say that.
So what's the best way to proceed?
I am based in Bristol, UK.
I am not allowed to let the file lout of my office, so the options feel
limited.
thank you for helping me by the way, Oliver.
Message 8 of 10
TrippyLighting
Answering my questions 😉
Message 9 of 10
I have no idea how to find that information out from Fusion 360.
it is the shape of a human knee bone ( tibia) so organic.
does that help? Oliver
Message 10 of 10
TrippyLighting
Of course that helps!
You should be very happy following the steps in this tutorial, which I created a few weeks ago specifically to address this sort of thing. Also if you do this more often, you should definitely add Autodesk Meshmixer to your tool shed.
Scanned geometry can have defects that MeshMixer can help repair.
