Hi All!
I'd like to discuss here the hierarchy of entities in GD model.
It's three level now: Model - Study - Load Case
1. Model is everything you have before GD - solid geometry (probably edited inside GD).
2. Study contains things you need to put together in order to formulate your task to GD algorithms - preserves, obstacles, materials, manufaturing and objective, etc.
3. Load case - as I understand - is a part of Study, a particular case where one could iterate and test "what if" hypothesis.
Everything seems fine but the fact that outcome space is shared between loads. So if I iterate new "what if" either in the same load case or clone it - I loose all previous outcomes and in fact cannot compare new and old case.
Why would anyone want to use more that one load case in Study?
Any thoughts regarding this topic are highly appreciated.
Pavel Medvedev
Курс по Fusion 360 на русском
Youtube on Fusion 360 in Russian - DadaPasha
Facebook | VK | Fusion 360 Telegram chat
