Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Fusion updated, but didn't!
10 REPLIES 10
Message 1 of 11
big_red_frog
647 Views, 10 Replies
Hi There,
( deleted responses from release thread, and started this clean one )
On launching Fusion I got an update dialog, and things spun away for a while, and then a clean desktop ( windows 7 )
I then launched fusion expecting it to be updated.
Carried on with a project, and then went looking for the import SVG improvements.
No sign of them, also noticing the viewcube still seemed broken when moving off the main window, which I understood to be fixed.
Checking the about box, it appears despite the apparent upgrade cycle, I am still on 1.8.604
I have tried a full reboot.
How do I get access to that 1.8.674 goodness?
Thanks.
10 REPLIES 10
Message 2 of 11
Would you please try to launch Fusion 360 once again and see if it can detect the update?
When you update to 1.8.674, you should be able to find the new 'Import SVG' command after create a new sketch.
Macro Liu
Fusion QA Team
Message 3 of 11
Closed and reopened, no indication of update. About still shows 1.8.604
Please advise.
Message 4 of 11
innovatenate
in reply to: big_red_frog
I had the same thing happen. I removed and then re-installed from the below link.
http://www.appstreaming.autodesk.com/install/app/73e72ada57b7480280f7a6f4a289729f/
Now my version is showing 1.8.674.
Keep us posted!
Nathan Chandler
Principal Specialist
Message 5 of 11
big_red_frog
in reply to: innovatenate
So I dont risk anything going bang, what method do you use to "remove" fusion?
Happy to try this, just want to ensure I dont mess up...
Message 6 of 11
big_red_frog
OK, found the proper uninstall for fusion 360 in control panel, running with that.
Message 7 of 11
big_red_frog
OK, and I am back up and running, about box shows new version, 1.8.674
Thanks.
Message 8 of 11
big_red_frog
You fixed the view cube, a thousand kudo's upon you from the part of my brain that hurt everytime the view jumped!
Message 9 of 11
AndrewSears
Did you find the SVG import?  If not, it is a little hard to find but the command to import a SVG file is not available unless you have an active sketch.
Andy
Message 10 of 11
big_red_frog
in reply to: AndrewSears
Found thanks, but left for another day.
Sent from Samsung tablet
Message 11 of 11
garin
There are lots of tasty little nuggets in there just waiting to be found. Looking forward to hearing how you like some of the new/enhanced tools.
Enjoy!!
