Fusion suitable for large scale objects? Is CAM multi-axis good?
calexpavel
calexpavel
 Fusion seems to be ideal for my needs because it has t-splines for complex shapes and cad, cam integrated. I am planning to use it for creating fiberglass furniture, but many people seem to be using it for smaller objects. So i was wondering if Fusion is suitable for 3 meters long objects for CAM and CAD. Is there any limitation in CAM for example? Is it developed with small objects in mind and does it have any issues with larger scale object?
I also wanted to ask if the CAM part is good for 4 axis CNC (one of the axis rotates 90 degrees). I've noticed that it supports multi-axis but i was wondering how good is it compared to other CAM softwares on the market?
Thanks!
jeff_strater
Hi @calexpavel.  Fusion should be fine for creating models of that size, using the modeling commands.  I can't comment on the CAM part, you might want to post that question here: Fusion CAM.
Jeff
Jeff Strater
Engineering Director
calexpavel
Thanks Jeff. When you say modeling do you refer to the CAD part also?
I'll ask in CAM section also. Cheers!
PhilProcarioJr
@calexpavel
Yes it is suitable for both.
As far as large scale models go I made a Train scale 1:1 with no problems.
The only real issue is with large and complex assemblies which doesn't apply to your use case.
Cam works really well, it has a few issues here and there but in my experience with other CAM packages they also have their own sets of problems.
Phil Procario Jr.
Owner, Laser & CNC Creations
ToddHarris7556
We use Fusion for museum exhibit design, which often involves some furniture-type cabinetry, some organic shape/sculpted items, and some mechanical interactives.
Most of our exhibits would be in the 500-5,000 SF range, with a few dozen exhibit 'modules'.
Fusion's not the *ideal* tool, but it has some amazing strengths - integrated CAD, rendering and CAM are near the top of the list.
With careful modeling, we can assemble exhibits that work pretty well for most of our (and our client) needs. With multiple people modeling, however, that 'careful modeling' piece can not be overemphasized. Sloppy / inefficient work can snowball quickly.
Develop good habits. It might be quick/easy to 'blast it out' and cut corners to try to get something out the door, but you'll regret every shortcut, every step of the way when you have to modify/revise something.
Todd
Product Design Collection (Inventor Pro, 3DSMax, HSMWorks)
Fusion 360 / Fusion Team
calexpavel
It's nice to have a feedback from someone who uses Fusion in production so much and not just for hobby. Yes, for 3d print or cnc, i guess the geometry needs to be done very well. It's good to have a package that has them all and you don't need plugins or other softwares to complete your work. In the same time it's hard to do more than one thing well..
