Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Fusion or Slicer problem?
20 REPLIES 20
Message 1 of 21
skipb48
838 Views, 20 Replies
 Basic info - running Fusion 2.0.19426 x86_64 [Native] Active Plan: Personal on a iMac with macOS 14.5
I need to know if the problems I'm having are due to drawing errors in Fusion, or is the problem in my slicer settings.
The first picture I'm uploading (Rings) is the beginning of the print, as you can see the inner and outer edges do not attach .
I started my CAD drawing with the Sketch1 and extruded that to 2 mm, then in Sketch2 I create a second circle and extruded that to 99 mm (including the Join option). In Sketch3 I drew a third circle and extruded that -101 mm to make the hole. It all seemed pretty simple, drawing wise .
When it came to slicing, I did reconfigure my slicer to set the outer and inner walls, both to be 2 mm in order to stiffen up the final TPU product. But when it comes to the actual print the inner diameter, and the outer diameter are not attached to the infill. So, how did I screw up this time? 😳
20 REPLIES 20
Message 21 of 21
wersy
in reply to: skipb48
Can you please explain in more detail what exactly the problem was?
Technology Administrators
