Fusion just stoped running because I have windows?
swimleft
Message 1 of 10
swimleft
I just went to log into fusion today and I find that errors out when starting. It says that Fusion 360 cannot be ran on windows. I have work to do using fusion and this is fairly infuriating.
I tried to reinstall the program and get the same error. see the image.Capture.JPG
Has anyone else had this issue?
Best,
Eric
Replies (9)
Message 2 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @swimleft,
Welcome to the Fusion 360 Community!
Just to check - have you ever had Fusion 360 working before? Personally, I have not seen this error in the past. I'd love to take a peek at your log files to get a better idea of what is happening. Can you send your installation log files to me at james.youmatz@autodesk.com. You can find the installation log files by following the steps in this guide here.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 10
swimleft
I have used it to run my machineshop for the past year.
I have used fusion as recent as last tuesday. I will get the files once I
have a sec later today.
Message 4 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @swimleft,
Hmm very interesting! I look forward to seeing the log files later.
James Youmatz
Message 5 of 10
swimleft
Here is the log
Message 6 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @swimleft,
Thanks for that! Can you do me a favor and try something. Can you open Windows Explorer and go to:
C:\Users\<yourusername>\AppData\Local\Autodesk\webdeploy\production\64cd1225aaecdd36644b12e5453e4d4c995e22b0
Please note to find the App Data folder you may need to enable hidden folders from the control panel. Once in that folder, you should see a program called Fusion360.exe and FusionLauncher.exe. Can you try to run Fusion360.exe (not the launcher) and see if that works? If so, I think your shortcut may have gotten messed up. If this runs like this, can you please send me your FusionLauncher.exe file to james.youmatz@autodesk.com (you may need to zip the file so it doesn't get blocked by email servers).
James Youmatz
Message 7 of 10
swimleft
I cannot find that extension in my fusion folder. Suggestions?
Message 8 of 10
Hi @swimleft,
Could you find the production folder? In that folder, there should be some alpha numeric named folders. If you sort them by date, the most recent one should contain the Fusion360.exe file.
Message 9 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Whoops! Looks like I was signed in under the wrong account. The post above is still me!
James Youmatz
Message 10 of 10
swimleft
So, I went to find the file you asked for. I could not find the .exe file.
BUT, the good (or bad) news. I decided to just uninstall Fusion and try reloading it again. This worked and now I am back up and running.
Thank you for responding quickly.
Best,
Eric
