Fusion is not saving a file
Message 1 of 17
I have spent some time and lots of work developing a project.  But Fusion has stopped saving the file.  In the Data Panel I get a continous spinning disc.  How can I get my file to save without losing any data?
Replies (16)
Message 2 of 17
innovatenate
Autodesk Support
Autodesk Support
I would start by making a local archive file for safekeeping.
Next I would try the following:
1. Work in Offline mode
2. Open the data panel
3. Locate and open the design that needs to be synced to Autodesk 360
4. Save a new version of this file while offline.
5. Go back online with Fusion 360
Does the design sync when you go back online?
Nathan Chandler
Principal Specialist
Message 3 of 17
Hi, thanks for the quick response.
I tried creating a local archive, but apparently this is not possible when the file containes Components
However I took the software off line and did a save as, then went back online.  The new file could not be uploaded either.
Do you have any other ideas?
Keith.
Message 4 of 17
innovatenate
Autodesk Support
Autodesk Support
Can you post the diagnostic log files here? They may help to reveal some further information regarding the issue.
Have you tried creating a local archive file from the A360 Dashboard? If you have a distributed design, a design with external references (XREF's) to other components, then the design will need to be exported from the A360 Dashboard.
You can access the A360 Dashboard by selecting the shortcut in the Data Panel..
...Or by logging into the dashboard in your webbrowser:
myhub.autodesk360.com
Then you can go throught process of exporting an F3Z file format. The isntructions are in the bottom half of this link.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
I look forward to your reply.
Kind Regards,
Nathan Chandler
Message 5 of 17
Diagnostocs files attached.
I have just downloaded the archive from A360, but I would prefer to keep my local file since it is more up to date.
Thanks Keith.
Message 6 of 17
innovatenate
Autodesk Support
Autodesk Support
I believe the two files below are the local versions that are trying to be uploaded. Do the names Chassis b v76 v0 and Chassis match with the files that will not save?
Type open library in terminal to access ~Library directory in Finder.
~Library/Application Support/Autodesk/Autodesk Fusion 360/***/W.login/F/Chassis b v76 v0.5e445c8f-cf54-474f-ba96-fbfd1effdd00.f3d
~Library/Application Support/Autodesk/Autodesk Fusion 360/***/W.login/F/Chassis.c6e99077-2c20-49b8-a7e9-aa53a4cd973a.f3d
I'm still looking for root cause information, server or local side. In the meant time, you may want to back-up the above file in your upload queue.
You may consider renaming and re-uploading them in the data panel to see if they are the right files. I hope this helps. I will be back with further information as soon as I have some.
Nathan Chandler
Message 7 of 17
innovatenate
Autodesk Support
Autodesk Support
I've sent you a PM with some instructions that will hopefully help to resolve the issue.
Let me know if you have any quesitons.
Nathan Chandler
Message 8 of 17
Ok, I've followed the instructions in the DM I got but this did not resolve the issue.
I think I have tracked the problem down though and I can recreate a software crash.
I have downloaded the latest Archive version from A360.
I then copy and past the component "Sensor PCB" from my local corrupt file into the new Archive file.
the operation when it does wrong is as follows:
In the new Archive file, I update the assembly "Line Sensor Array" so that component "IR PCB" is no longer visible.
I then go back to the Chassis assembly and update the outdated component.  Fusion 360 then crashes. with the support code CER_121829249
Hope you can help.  Many thanks.
Keith.
Message 9 of 17
Add error reports
CER_121829351
CER_121828791
To that list
Keith.
Message 10 of 17
Phil.E
@innovatenate He's crashing into a known bucket that appears to be data related. FUS-19920. Can you get the crashy data set and attach it to the bug report?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 11 of 17
innovatenate
Autodesk Support
Autodesk Support
@Anonymous I've sent you a direct e-mail to share date with. Please let me know if you don'tr receive it.
Nathan Chandler
Message 12 of 17
neljoshua
I am having a similar issue.
Fusion is not saving my current work, although it appears to be saved locally.
I have attached my diagnostic logs.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Message 13 of 17
brianrepp
@neljoshua apologies, but this is likely related to the current outage we're experiencing.  Please see here for additional details and updates:  http://forums.autodesk.com/t5/design-validate-document/a360-unexpected-server-error/td-p/5976108/pag...
Message 14 of 17
neljoshua
Thanks for the quick reply.
I was able to re-open the file (after having to force quit Fusion).  After restarting, the other versions uploaded and all appears to be well.
__
Message 15 of 17
brianrepp
Just a heads-up, we believe we have fully restored all cloud services and you should be back to normal.  If anyone is still experiencing any issues, please let me know.
Message 16 of 17
Nathan,
It looks like we are running again.  I attempted to backup and received an error message saying that it cannot export and archive a file with links attached.
Allan Steinkuhl
Message 17 of 17
innovatenate
Autodesk Support
Autodesk Support
Thanks for the update! Are you able to export the archive file if you use the export command on the A360 Dashboard (web browser)?
Nathan Chandler
