Fusion crashes when using pattern
camstuff
camstuff
I am needing to make a perforated panel for a gun range and during the sketching of the holes when I pattern the final layout Fusion stalls on 'updating graphics' then crashes.  I have tried over 20 times, but no way will it finish.
Mac pro
Fusion build - 2.0.2938
Thanks Cam
JDMather
@camstuff wrote:
.... during the sketching of the holes when I pattern
It is (almost) always preferable to pattern features rather than sketch entities.
Can you attach your *.f3d file here that exhibits this behavior?
camstuff
Thank you I did just that and was able to work my through it 🙂
Its on the machine cutting as I type YAAA
Thank you for the reply!
Cam
