Hi @Anonymous
Thanks for posting! It looks like you are experiencing an issue in which models imported to Fusion 360 are always using metric units.
I tested this on my end and noticed that native Fusion designs will maintain the active units defined in the browser of their original file. What format files are you importing?
I noticed, when testing with STEP files, that using the "New Design from File" option in the File menu would allow an imported STEP file to enter with my default units - in this case inches. However, when I uploaded the same STEP file to Fusion through the data panel, the active units come in as millimeters. This is shown in the screencast below.
This illustrates a limitation of the cloud translation framework while uploading through the cloud/data panel - the base units for the STEP format file (millimeters) are used, overriding the defaults in Fusion. This is, however, easy to work around by simply changing the active units - I have also shown this in the screencast below.
Hopefully this helps! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
