Importing....
Importing....
Importing....
I have my default units set to inches, yet whenever I import a model, the resulting design always has the units set to mm.  Shouldn't the Import functions LOOK at the users default units. or perhaps ASK the user??
Ray L.
paul.clauss
Hi @Anonymous
Thanks for posting! It looks like you are experiencing an issue in which models imported to Fusion 360 are always using metric units.
I tested this on my end and noticed that native Fusion designs will maintain the active units defined in the browser of their original file. What format files are you importing?
I noticed, when testing with STEP files, that using the "New Design from File" option in the File menu would allow an imported STEP file to enter with my default units - in this case inches. However, when I uploaded the same STEP file to Fusion through the data panel, the active units come in as millimeters. This is shown in the screencast below.
This illustrates a limitation of the cloud translation framework while uploading through the cloud/data panel - the base units for the STEP format file (millimeters) are used, overriding the defaults in Fusion. This is, however, easy to work around by simply changing the active units - I have also shown this in the screencast below.
Hopefully this helps! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
I've mostly been importing Solidworks models, through the data panel.
Ray L.
paul.clauss
Hi @Anonymous
Thanks for the response! Using the "New Design from File" option should resolve this issue - please let me know if the behavior you experience differs from my screencast above and we will continue troubleshooting.
Paul Clauss
"New Design from File" does not support import of Solidworks models, only STL, IGES, etc.
Ray L.
paul.clauss
Hi @Anonymous
Good call - that was my mistake! Unfortunately, you will need to use the active units option in the browser to change the units when working with parts imported from SolidWorks. We apologize for this inconvenience!
Paul Clauss
