Hi
Welcome to the forum 🙂
YouTube and look for Lar Chrstensen, there are good vid on the Autodesk website but not nearly enough.
Ditch any learn knowledge on CAD systems, Fusion does things differently (and sometimes very annoyingly sometimes brilliantly)
You start with a Sketch on a plane, (I'm sure that was a film ha ha), do something to make it a solid - extrude, revolve etc
Add detail if needed by adding a sketch on a plane or on a face of the solid made above
Come back here because you'll be pulling your hair out by then
Matt
Hello @Anonymous
Thanks for posting your problem in Autodesk Forum.
You Can Learn About the Fusion 360 At given Link.
https://academy.autodesk.com/software/fusion-360
Best Regards
Anil Kumar
(Student Expert)
There are many hours of learning materials just in this link collection right on top of the Fusion 360 forum. Ia massing this escaped your attention because t as hidden in plain sight ?
Also, the top menu row contains a menu called Support & Learning.
@docara Be careful of who you take advise from. Lars, NYCNC and a number of other folks are CAM guys and they know that stuff very well. However, you don't usually start out with CAM, first you have to model something. I'd be careful taking modeling advice from a CAM guy. I've seen one video where I identified 10 No-No's in 15 minutes and that person has "teacher" in his user name.
In general, for modeling and assembly advise you are much better off here on the forum!
