Disk with two materials
Disclaimer: New to Fusion and CAD design
So I have been looking into materials in Fusion and here is my problem. I want to 3d print a model. Basically i want a circle that from [0 r1] has one material and from ]r1 r2] has another material.
When I use the combine feature, even if i specify different material before everything becomes the same and I loose the limit of the central circle.
I also tried making two different bodies: A circle from 0-r1 and and a ring from r1 to r2 and then import them as two seperate models to simplify 3d (this is the program that I use to connect to the printer). Well did this not work since I can't overlap the models and print in the same place.
Does anyone have any tips?
Thank you for sharing your problem @Anonymous
For Material changing, you have to use command Appearance and select the material from material library and get the desired output that you want.
Hope the above information helps you!!
From
Bhavesh Raghwani
cesar.gironU5U5A
Generaly bi-material printer require 2 different model that you then add to you printing slicer.
There is an old trick for this kind of interference problem which is to put a minute gap between your two parts (0.0001 mm) insignificant in real life yet your computer might not compute an overlap as long as you can precisely position your model. I dont use simplify 3D so i cant tell you whats the minimum gap.
Due to material retraction your outer disque might crush the inner one (so maybe a little more than a minute gap) well it's gonna be a bit of trial an error.
