Welcome to the community! I'm sorry to hear you're having trouble starting Fusion 360. Thanks for submitting the error reports. I note that your graphics drivers are up to date and ready to go, so we can rule out graphics right out of the gate!
I note that everything seems to go haywire in the log files after loading the below file.
%appdata%/Autodesk/Neutron Platform/Options/<ID>/NGlobalOptions.xml
Can you try the following suggestions to see if they help? I'm including Mac instructions for other's benefits.
Mac OS
1. (Close Fusion 360) In Terminal, type the below command and press enter
open ~/library/
2. In the Subsequent Finder window (Macintosh HD > Users > %Profile% > Library), browse to
~/Library/Application Support/Autodesk/Web Services
3. In the Web Services Directory, locate the file LoginState.xml
4. Right click on LoginState.xml and select Move to Trash
5. Restart Fusion 360
Windows OS
1. (Close Fusion 360) In windows explorer browse to %localappdata%\autodesk\web services
2. In the Web Services directory, right lick on the Login State.xml file and select delete
3. Restart Fusion 360
One more thing to try ....
Mac OS
open ~/library/
~/Library/Application Support/Autodesk/Neutron Platform/Options
3. In the Web Services Directory, right click on the file NMachineOptions.xml and select Move to Trash
4. In the Web Services Directory, right click on the file NGlobalOptions.xml and select Move to Trash
Windows OS:
1. (Close Fusion 360) In windows explorer browse to %appdata%\autodesk\nuetron platform\options
2. In the Options directory, right click on the NMachineOptions.xml and select delete
3. In the Options directory, right click on the NGlobalOptions.xml and select delete
4. Restart Fusion 360
If the above suggestions do not help , can you try performing a clean unisntall using the below link?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
This will make sure that all of the previous files have been removed. After this, perform a fresh install by selecting Download Free Trial from the below website.
http://www.autodesk.com/products/fusion-360/overview
I hope this helps! Please keep us updated on your progress!
Nathan Chandler
Principal Specialist
