Fusion 360 Won't open at all
MichaelTewasart
Message 1 of 69
MichaelTewasart
I can't open up Fusion 360 at all.
Every time I try and click on the icon, my cursor would have a small downloading icon for a few seconds. Then, it would disappear.
I would appreciate it if anybody can help!
Replies (68)
Message 21 of 69
MichaelTewasart
I have Norton 360. You want me to uninstall it before I use Reno Uninstaller to completely remove Fusion 360?
Message 22 of 69
Beyondforce
No, just disable Norton and run the installation again as administrator.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 23 of 69
MichaelTewasart
So I've temporary disabled Norton 360, and the Fusion 360 as administrator...and IT STILL won't let me install Fusion 360.
What now?
Message 24 of 69
Beyondforce
Restart your computer, disable Norton and try to install again.
Ben Korez
| YouTube
Message 25 of 69
MichaelTewasart
It now works splendidly. Thank you very much!
Message 26 of 69
Beyondforce
Great! If you need more help, we are all here for you 🙂
Ben
Ben Korez
| YouTube
Message 27 of 69
For me simply disabling bitdefender antivirus 2017 free protection allows Fusion 360 to start. This is a problem now. Which program do I choose? Stupid web apps...
Message 28 of 69
kshea9RNL8
No problem here with Malwarebytes and have used the free Microsoft Security essentials software with no issues.
Message 29 of 69
Lepard007
@Beyondforce wrote:
If you have an Antivirus software, then you must disabled it!
I am having continuous problems with FUSION 360 launching. Its never the same and sometimes i wind back the windows updates and sometimes i restart. I have trend micro internet security and i have to put it in mute mode everytime other wise it doesnt get past the landing page. I have updated graphic drivers and i have done the re-install, i have even bought a new HP Spectre computer as i thought it was the old HP not performing etc etc. This computer has the latest graphics supposedly the best but i still have this ongoing intermittent problem and it is driving me nuts!!!!!!!!!
I see on the net there are so many people reporting this problem but it is not being solved.
Can someone at FUSION 360, take notice of this signal and instead of modifying the program can you work on the fix for this problem?? ?
Message 30 of 69
Lepard007
Message 31 of 69
Beyondforce
Hi @Lepard007,
First, we must figure out what causes the problem? If you disable the Antivirus, does it helps?
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
| YouTube
Message 32 of 69
fusion 360 wont open
Message 33 of 69
I am having the same problem with Fusion 360  (On Windows Version 10.0.19041 Build 19041) .
Once i start it nothing happens, No dialog, No message, No windows event, the task just stops
I have tried
  1. Re-install
  2. Clean re-install (removing all %AppData%\AutoDesk folders on Local & Roaming)
  3. Disable antivirus
Nothing works!
Any help would be appreciated
Message 34 of 69
Beyondforce
Right-click on the EXE file and run it as Administrator. If that doesn't help, then you gonna need to do a system restore to a point in the past where F360 used to work.
Let me know if it helps!
Cheers / Ben.
Ben Korez
| YouTube
Message 35 of 69
Hello Ben.
I tried running the application as administrator same behaviour.
Application starts but is only visible as a process in task manager (no
view/dialogs).
JohnLeo
Message 36 of 69
Beyondforce
Next, you should try is System Restore. This tutorial will help you with that: https://www.windowscentral.com/how-use-system-restore-windows-10
If you don't have a point to restore to, then you will have to reinstall windows!
Ben Korez
| YouTube
Message 37 of 69
Beyondforce
Try do manual uninstall first:
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Ben Korez
| YouTube
Message 38 of 69
I have now completely re-installed windows and installed fusion 360 before
anything else.
It still fails.
Any other suggestions?
Message 39 of 69
TheCADWhisperer
I am lost - you should have started a new thread.
Q1. What build of Windows OS are you running?
Message 40 of 69
Beyondforce
Something is not right! I would like to add to @TheCADWhisperer question... what is your computer specs?
Ben Korez
| YouTube
