Fusion 360 website & Joint editing
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have two issues at the moment...
1) The Fusion 360 "Community" page on the website has never displayed properly, which prevents me from getting to the forum. In fact, I usually resort to using Google to find the forum since the web page is mostly obscured by a large blue bar. I have zoomed in and out, but the bar remains in the way of all clickable options. Unless there are no options on this page? In that case, how do I get to the forum from the time I sign in???
2) I have successfully created joints using the Assemble > Joint commands, which was incredibly difficult for some reason. I imported my Rhino file so I'm guessing this may be the cause. After an hour of frustration with all of my components being "grounded", I finally discovered a way to unground them. I should note that they were never grounded using the option to ground, this was never selected and to be sure, I imported them three different times. I resorted to converting them somehow, but since there is no history of my clicks I cannot find out exactly what I did.
So now I used the Joint command, but didn't get things aligned correctly. I want to adjust the joints, but this is not an editable function for some reason. Do I start over? I can't get the parts unjoined so I'm guessing Fusion wants me to start a new file? I tried the Joint command again and the error states it is already joined.
I watched several videos on this topic and none of them address these problems. I would much appreciate any insight.
