We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Fusion 360 website & Joint editing
Message 1 of 8
I have two issues at the moment...
1) The Fusion 360 "Community" page on the website has never displayed properly, which prevents me from getting to the forum. In fact, I usually resort to using Google to find the forum since the web page is mostly obscured by a large blue bar. I have zoomed in and out, but the bar remains in the way of all clickable options. Unless there are no options on this page? In that case, how do I get to the forum from the time I sign in???
2) I have successfully created joints using the Assemble > Joint commands, which was incredibly difficult for some reason. I imported my Rhino file so I'm guessing this may be the cause. After an hour of frustration with all of my components being "grounded", I finally discovered a way to unground them. I should note that they were never grounded using the option to ground, this was never selected and to be sure, I imported them three different times. I resorted to converting them somehow, but since there is no history of my clicks I cannot find out exactly what I did.
So now I used the Joint command, but didn't get things aligned correctly. I want to adjust the joints, but this is not an editable function for some reason. Do I start over? I can't get the parts unjoined so I'm guessing Fusion wants me to start a new file? I tried the Joint command again and the error states it is already joined.
I watched several videos on this topic and none of them address these problems. I would much appreciate any insight.
Replies (7)
Message 2 of 8
brianrepp
Hey Jason - re: the community hub not rendering properly, would it be possible to get a screenshot?  Also, what browser (and version) are you using?
~Brian
Message 3 of 8
Message 4 of 8
This is how it looks unless I zoom out as far as possible.
Message 5 of 8
joel.palioca
Hi Jason,
Sorry to hear your having issues with joints.  Since it sounds like you have a couple different issues with joints would you be able record a video with the issues you are seeing, as well as share the file in question?  You could either upload it to the forums or email me directly.  This way I can understand exactly what you are trying to do and can hopefully offer some advice or recommendations on how best to approach things.
Cheers,
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Autodesk, Inc.
Message 6 of 8
brianrepp
Thanks, Jason - what version of Firefox are you running?
Message 7 of 8
keqingsong
@Anonymous , regarding your assemble > joint questions, let's help you out over a skype/google hangout session. Shoot me an email at keqing.song@autodesk.com and we can set up a time and go from there.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 8 of 8
The problem is that the parts are permanently grounded even though I have not selected to ground them. My guess is that Fusion is not really designed to import files as importing files always causes multiple problems.
