Fusion 360 to Sim CFD
What is the easiest way to import a solid model step file into Fusion360 and then launch Sim CFD?
Andrew.Sartorelli
Hi @Anonymous,
Newer versions of Autodesk CFD (2016 and 2017) actually include a product called SimStudio Tools. It will allow you to make changes to your model with many of the tools you are familiar with inside of Fusion, but with has some features just for simulation users. You can check out the SimStudio Tools help for more information on what features are there.
Andrew
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Andrew Sartorelli - Autodesk GmbH
innovatenate
Autodesk Support
Autodesk Support
Today, there is no add-in that will allow you back and forth (like the Inventor Add-In) with SIM CFD. You can however export and import as needed to modify geometry in Fusion 360.
I hope that helps!
Nathan Chandler
Principal Specialist
innovatenate
Autodesk Support
Autodesk Support
@Andrew.Sartorelli Good point! Totally blanked on that!
Nathan Chandler
