Fusion 360 locks up!
EdDRM
Message 1 of 43
EdDRM
 I tried to insert a bolt form McMaster-Carr and Fusion 360 locked up.
I had to force shut down in the task manager.
I tried STEP and SAT with the same result.
I tried a nut and a bolt with the same result.
Is there an issue with Mcmaster-Carr?
Replies (42)
Message 41 of 43
Phil.E
Windows tool libraries are stored in
C:\Users\xxx\AppData\Roaming\Autodesk\CAM360\libraries\Local
Windows local templates are stored in:
C:\Users\xxx\AppData\Local\Fusion 360 CAM\templates
Mac local tool libraries are stored in:
Library\Application Support\Autodesk\CAM360\libraries\Local
Mac local templates are stored in:
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
Message 42 of 43
EdDRM
Update:
I updated my OS to Windows 10 and now I am able to Insert a .step from McMaster. 🙂
I have only tried this twice.
I did get the black screen over the browser area for a few seconds but Fusion made it thru it with out shutting down.
The black screen over the browser area usually happens right before Fusion shuts down unexpectedly. (I think this is common I have seen it on a few webcasts)
Message 43 of 43
kenninjensen
Hello
I am having the exact same issue as mentioned in this thread. Fusion is locking up.
To answer the questions asked:
- Just found out about the mcmaster import function today
- I'm running Windows 7 (SP1)
Fusion lock's up, but not completely. It is possible to hover the mouse above some of the buttons in the McMaster-window, and the program seems to react to it. (Se picture/attachment)
I cant click on anything though.
Hope it can be solved sometime, since it is a neat feature.
Regards, Kenni
