Fusion 360 locks up!
EdDRM
Message 1 of 43
EdDRM
 I tried to insert a bolt form McMaster-Carr and Fusion 360 locked up.
I had to force shut down in the task manager.
I tried STEP and SAT with the same result.
I tried a nut and a bolt with the same result.
Is there an issue with Mcmaster-Carr?
Replies (42)
Message 21 of 43
Phil.E
Can both of you please send me via email your diagnostic logs?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 22 of 43
EdDRM
Just checkin in to see if we made any progress.
Thanks again for the help.
Message 23 of 43
EdDRM
I have Google as my default browser.
I did have a AVG extention on it but I removed it when I ran into this issue.
Message 24 of 43
Phil.E
One more question:
What is the system anti-virus for both of you?
Any web anti-virus separate from that?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 25 of 43
JayCampbell7952
Kaspersky
Message 26 of 43
EdDRM
AVG
Message 27 of 43
Phil.E
We should probably check if the files ever get downloaded.
Can you check in windows explorer:
%temp%/neutron
There should be a bunch of files there, and your downloaded .step files should be there.
If they are not, they are not being downloaded.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 28 of 43
EdDRM
Only 3 older files there.
Message 29 of 43
EdDRM
Not sure if you guys and gals work weekends but if you need anythig I'm here.
Message 30 of 43
Phil.E
We do sometimes work weekends like this one, but we were all busy with the update. 🙂
When you say "3 older files" do you mean that they aren't STEP files from McMaster-Carr?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 31 of 43
EdDRM
Yes, There are no .step files from McMaster-Carr.
Message 32 of 43
EdDRM
Looks like a awesome update!
Message 33 of 43
EdDRM
Any progress?
Message 34 of 43
Not at this time.
We cannot reproduce it, and we can't figure out what might be causing it.
So we need more users to come forward, and/or need a breakthrough with your case.
At this point you could try a clean re-install. Please use the instructions for uninstalling from this page.
http://forums.autodesk.com/t5/design-validate-document/fusion-360-readme/td-p/4311780
Outside of that, you can always download the files as STEP and upload them to your data panel manually. Or open them with "New Design from File" so you can copy+paste them into your design. I know it's a workaround, but you aren't blocked from using McMaster parts entirely.
Please let us know how it goes.
Message 35 of 43
EdDRM
Ok thx for the heads up.
What is lost if anything when I do a clean install?
The only thing I would be concerned of losing would be my tool library.
I have some CAM templates as well.
I have another PC maybe I'll install fusion on it when I get some time and se what happens.
Message 36 of 43
Phil.E
The answer above is me, was logged in as a test user. 🙂
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 37 of 43
sanjay_jayabal
Hi folks,
One thing that I would like you to try before attempting a reinstall - from the Help drop down, can you "Clear user cache data" and see if that helps?
best regards,
Sanjay Jayabal.
Message 38 of 43
Phil.E
If you have local libraries for CAM, you should copy them prior to re-installation. After re-install you can paste them back into this location.
C:\Users\xxx\AppData\Roaming\Autodesk\CAM360\libraries\Local
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 39 of 43
EdDRM
Still no luck after clearing cached data.
Message 40 of 43
EdDRM
Is there any way to save the CAM templates?
