Fusion 360 - How can I increase the polygons on a cylinder?
cwalsh561
Message 1 of 15
cwalsh561
I've designed a smokebox for a model locomotive which looks great in Fusion  but the cylinder has flats.  Is there a way I can increase the polygon count to make a smoother print?
Replies (14)
Message 2 of 15
aliobidi
Hi ,
in sketch there "polygon " use it and increase it
Message 3 of 15
sutherland-
Hi @cwalsh561
Did you create a polygon sketch or circle sketch?
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Message 4 of 15
cwalsh561
It was a circle sketch which I extruded over the inner shell.
Message 5 of 15
sutherland-
Do you mind sharing the model here, so we can find a solution for your issue?
Best regards,
Level  sutherland-
Member
Message 6 of 15
g-andresen
choose a better resolution for the mesh export
günther
Message 7 of 15
cwalsh561
Yes of course.  It's on this link:
https://a360.co/3s4p6kF
Message 8 of 15
g-andresen
unfortunately the download was not allowed or you are using a personal license that does not include this option.
Please share the file this way:
File > export > save as f3d on local drive  > attach it to the next post.
günther
Message 9 of 15
cwalsh561
Thanks Gunther.  I am using a personal licence and so I've attached the file to this post.
Chris
Message 10 of 15
sutherland-
Thanks for sharing the model.
Are you using Fusion 360 for printing or some other software?
Best regards,
Level  sutherland-
Member
Message 11 of 15
g-andresen
These are the results in Prusa Slicer at different resolutions.
günther
Message 12 of 15
billbedford
Message 13 of 15
cwalsh561
I usually export an obj or an stl file and then slice it in Lychee slicer for the resin printer.
The Prusa settings on the Fusion file are there just because there is no setting for Lychee slicers or, indeed, ChituBox.
Best regards,
Chris
Message 14 of 15
g-andresen
The result in the slicer depends on the quality of the exported file.
The exports as 3mf (STL gives the same results) were made in Fusion in the specified resolutions.
Any slicer should accept these formats.
günther
Message 15 of 15
cwalsh561
Thanks Gunther,
I've increased the resolution as you suggested and the results in the slicer look great.
Best regards and thanks again.
Chris
