Fusion 360 - Problems with "Render" function
Tar3q-up
Message 1 of 9
Tar3q-up
Hello all,
When I render my 3D model " In-canvas" , I get the result that I desire. However, I need higher resolution renders and therefore need to use the Render option, which allows me to generate high resolution renders (i.e. particular image size). Unforuntately, this Render option gives me very weird results, with weird reflections and overall poor quality. Material is matte PLA so I have no idea where the reflections come from.
Figure 1 enclosed is the "In-canvas" render and Figure 2 is the properly rendered image (using Cloud renderer with Final render quality).
Any ideas on how to fix this?
Best,
Aat
Replies (8)
Message 2 of 9
sutherland-
Hi @Tar3q-up
Do you have any errors in your Assembly/Timeline? Both red and yellow?
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Message 3 of 9
Tar3q-up
No I don't have any errors. These are simply imported meshes (not assembled/designed in fusion). The meshes were wrapped to make them "watertight" and suitable for analysis (and with that I hoped for proper rendering).
Message 4 of 9
TrippyLighting
This is a bug that has been reported several times  and has been recognized by AD.
Message 5 of 9
Tar3q-up
Any workarounds reported?
Message 6 of 9
sutherland-
For now I guess the solution would be to use other render software, while Autodesk is working on it.
Best regards,
Level  sutherland-
Member
Message 7 of 9
Tar3q-up
That is unfortunate, thanks for your reply!
Message 8 of 9
TrippyLighting
Nope!
This bug appears to only effect imported mesh models. I personally don’t see any reason to use the Fusion 360 render engine to render mesh models because there are much, much better, free alternatives
available. E.g. Blenders internal renders Eevee and Cycles.
Message 9 of 9
sutherland-
I will have to agree with what Trippy said.
F360 is great for modelling and quick renders with native files.
Best regards,
Level  sutherland-
Member
