Can we perform topology optimization using Fusion 360
akilan.s2020KHN76
Observer Observer
akilan.s2020KHN76
Observer
Observer
I am a researcher working on topology optimization and I am new to AUTODESK FUSION 360. Can you suggest me the workflow of how to perform topology optimization using this tool. I found my tutorials in youtube performing shape optimization as topology optimization, Is it correct or Is there any other option to perform topology optimization using AUTODESK FUSION 360.
sutherland-
Hi @akilan.s2020KHN76
I am not sure which video you have seen, but Fusion 360 does support shape optimization.
There is a step-by-step video here.
You can read TOPOLOGY OPTIMIZATION post to get more information on this feature.
Please feel free to ask more if you have any specific questions.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
akilan.s2020KHN76
Observer
Observer
Thanks for your reply sir, But is shape optimization and topology optimization same sir.
sutherland-
I was just making sure to include both. 🙂
Did my reply answer your original question?
Best regards,
Level  sutherland-
Member
akilan.s2020KHN76
Observer
Observer
Sir, I am aware that shape optimization can be performed with this tool, but for my research, I need to verify whether shape optimization and topology optimization results are the same using this tool sir.
laughingcreek
no, they are not the same. topology optimization  only involves static FEA, while shape optimization  also includes non-linear.
There's a plethora of published academic research on this subject out there.  might be a good idea to do a review before proceeding with your own research.
