Fusion 360 fails to insert DXF file?
Art5
Message 1 of 9
Art5
I'm trying to open a dxf that I exported out of fusion a few months ago for use with our plasma cutter. When I try to open the file I get an error; 'Fails to insert this DXF file!'
I don't understand why this is happening, seems like fusion should be able to open a file that it exported. Opened fine on the plasma cutter software. I just wanted to make a couple minor edits and can't find the original file, so I figured I would just pull the exported dxf back in, but to no avail.
Any and all help is greatly appreciated,
Art
Replies (8)
Message 2 of 9
HughesTooling
Are you using Insert DXF or are you uploading to your hub?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 9
Art5
Using "Insert DXF". Also tried "Open". Same error either way. Never had this issue before.
Message 4 of 9
HughesTooling
I think both of those use local translators. Try uploading the file to a project on your hub, may be the cloud translator will work. Can you share the DXF here?
Thanks Mark
Mark Hughes
Message 5 of 9
Art5
Uploading to the hub worked. Wonder why insert didn't, I've opened hundreds of dxf files that way before, never had an issue before today.
Message 6 of 9
HughesTooling
Is insert DXF still working OK today with other DXF files?
Mark Hughes
Message 7 of 9
Art5
Now that you mention it, I just tried a couple others that I've opened before and I'm getting the same error on all of them.
Message 8 of 9
Art5
Just another of the countless fusion bugs, I suppose. Something to add to the ever-growing list of things for the fusion team to look into.
Message 9 of 9
HughesTooling
There is another thread with a couple of people with the same problem. Still works fine for me so could just be a corrupt update, with any luck the next update might fix the problem.
Mark Hughes
