Fusion 360 Drawings cannot launch
maciej.jagodzik
Message 1 of 12
maciej.jagodzik
Hello ,
I have a problem with Fusion i reinstal 3 times and still doesn't work.
Help
Replies (11)
Message 2 of 12
RajkumarIlanchelian
Sorry that our update caused these errors for you. I am going to assume that you are on windows and if you can try the below and let me know:
1. Go to your ProgramData- Autodesk
2. Delete FusDoc folder
3. Restart Fusion 360
This should fix the problem for you. Please let us know if this helped.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 12
maciej.jagodzik
yes it works, Thanks
Message 4 of 12
I am not having any luck with this. I have tried uninstalling and reinstalling an that doesn't work.
I can't find the Program Data folder, I can find the Program Files folder but there is not an Autodesk folder there.
Need this working asap for business use !
Message 5 of 12
maciej.jagodzik
on C drive you need to enter in the view (at the top of the window) and show the hidden elements, then you find ProgramData Folder
Message 6 of 12
RajkumarIlanchelian
ProgramData is a hidden folder in Windows.
Here is a link from Microsoft that shows how to turn on hidden folders - https://support.microsoft.com/en-us/help/14201/windows-show-hidden-files
Hope this helps.
Autodesk Fusion
Join Fusion Insider
Message 7 of 12
Sorted ! Thanks
Message 8 of 12
I had the same problem but this procedure doesn't fix the problem for me. When I delete the Fusdoc folder I just can't launch Fusion360 at all anymore...
Message 9 of 12
RajkumarIlanchelian
Did you do any uninstall of the product before you found this workaround? Also did you try a restart of your machine to see if that helped?
Autodesk Fusion
Join Fusion Insider
Message 10 of 12
At first I uninstalled and reinstalled the product as recommended in the error message. Tried to launch designs but it still wasn't working.
Then I deleted the Fusdoc folder as you said and tried to restart Fusion without restarting the machine. Here Fusion didn't launch at all.
So I tried restarting the machine then, here Fusion can be launched but the issue of drawings launching is still there.
Message 11 of 12
RajkumarIlanchelian
Can you please do a couple of things for me:
1. launch Fusion and go to Help - Diagnostics log files
2. This will generate a zip file. Please email it to [email protected]
3. Close Fusion
4. Delete the FusDoc folder
5. Now start Fusion again and see if that fixed it for you
Sorry that this is taking longer than it should be.
Autodesk Fusion
Join Fusion Insider
Message 12 of 12
hii rajkkumar ur post helped thank u where r u from india
