Fusion 360 destroys itself
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- パーマリンクを表示
- 印刷
- 報告
I started Fusion
There were interface glichtes like the mouse courser gone in a new sketch
Then buttons became unresponsive and Fusion crashed.
Trying to start it again gives me now this message:
This is also now the second time Fusion created this error when starting it. Last one was because after the update the app link did not work
or was still directed at the old web deploy version and not the new. Checked this time and the link is corrent.
Could you please at one point install Fusion like any other application? My OS X folder is filled with all those
all eb deploy garbage left overs ...
Going to wipe Fusion of the HD and re-install again.
Error Details:
Process: Autodesk Fusion 360 [596]
Path: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Identifier: com.autodesk.fusion360
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Autodesk Fusion 360 [596]
User ID: 501
Date/Time: 2015-08-19 12:25:17.155 -0400
OS Version: Mac OS X 10.10.4 (14E46)
Report Version: 11
Anonymous UUID: 6E7D6BE1-937E-13A8-C7ED-990252E4931B
Time Awake Since Boot: 100 seconds
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/Qt/QtCore.framework/Versions/4/QtCore
Referenced from: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/Autodesk Fusion 360
Reason: image not found
Binary Images:
0x7fff61533000 - 0x7fff61569837 dyld (353.2.1) <72A99D0F-0B56-3938-ABC5-67A0F33757C4> /usr/lib/dyld
Model: MacPro3,1, BootROM MP31.006C.B05, 8 processors, Quad-Core Intel Xeon, 2.8 GHz, 10 GB, SMC 1.25f4
Graphics: NVIDIA GeForce GTX 970, NVIDIA GeForce GTX 970, PCIe, 4095 MB
Memory Module: DIMM Riser B/DIMM 1, 1 GB, DDR2 FB-DIMM, 800 MHz, 0x830B, 0x4E543147543732553850423942442D324320
Memory Module: DIMM Riser B/DIMM 2, 1 GB, DDR2 FB-DIMM, 800 MHz, 0x830B, 0x4E543147543732553850423942442D324320
Memory Module: DIMM Riser A/DIMM 1, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323546373243503844332D5335
Memory Module: DIMM Riser A/DIMM 2, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323546373243503844332D5335
Memory Module: DIMM Riser A/DIMM 3, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323546373243503844332D5335
Memory Module: DIMM Riser A/DIMM 4, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323546373243503844332D5335
Bluetooth: Version 4.3.5f8 15969, 3 services, 26 devices, 1 incoming serial ports
Network Service: Ethernet 2, Ethernet, en1
Serial ATA Device: SanDisk SDSSDHII240G, 240.06 GB
Serial ATA Device: KINGSTON SV300S37A240G, 240.06 GB
Serial ATA Device: ST3500830AS, 500.11 GB
Serial ATA Device: ST500DM002-1BD142, 500.11 GB
Parallel ATA Device: OPTIARC DVD RW AD-7170A
USB Device: Hub
USB Device: Microsoft® LifeCam Studio(TM)
USB Device: Logitech G330 Headset
USB Device: SoundSticks
USB Device: Keyboard Hub
USB Device: USB Receiver
USB Device: Apple Keyboard
USB Device: Bluetooth USB Host Controller
USB Device: DTZ-1200W
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
