Message 1 of 22
Hello guys, since the last update Fusion 360 crashes when i try to edit sketches. Any suggestions, thanks for reading.
I was able to add circles at the center at 7.25 and 6.00. It just takes a long time:
Which brings us to the subject of complex sketches and performance. In general, complex sketches in Fusion are not a good idea. The performance will not be acceptable in a sketch of this complexity. This looks like some kind of sprocket or gear. You would be much better off to just model one of the teeth in a sketch, and use feature pattern to model the rest of the teeth.
Jeff
Thanks. An important lesson learned. SVG files can import a lot of complexity that may need to be simplified. In my case each tooth comprised hundreds of line segments. But by using a spline and a couple of lines I was able to create a tooth face, then use mirror symmetry and circular patterning to create a complete gear with 60 teeth that does not crash and is accurate enough for my purpose.
