Best way to design zipper
connorvega1
Message 1 of 10
connorvega1
I'm doing a design of a bag, sort of like a diaper bag. It is product design, not meant for manufacturing (at least not yet). Naturally the bag has zippers. My question is how best to model the zippers? Is there an easy way to model it in fusion 360, or is it just best to model a surface strippe and put on it a zipper texture?
Thanks!
Replies (9)
Message 2 of 10
Pavel_Holecek
I not sure if this is really what you want, but for the zipper is possible to use 'Pattern on Path' command which enables you to patter a body along 2D/3D curve.
I attached an example.
Regards
Pavel Holecek
Autodesk QA team
Message 3 of 10
connorvega1
Wow that is totally dope! Thanks!
Message 4 of 10
sennokanmuri
it's beautiful! We will consider it as a reference! Thank you.
Message 5 of 10
lichtzeichenanlage
@Pavel_Holecek: That's a great work. What do you think about patterning faces instead of bodies?
Message 6 of 10
Pavel_Holecek
I think that it is much easier to select one body instead of many faces. If you select all faces then pattern creates a new body for each instance.
Pavel Holecek
Autodesk QA team
Message 7 of 10
lichtzeichenanlage
@Pavel_Holecek: True - it's easier to select. But aren't faces and features faster to process for Fusion 360? Keeping things fast isn't to ignore in my experience.
Message 8 of 10
hi i'm a complete beginner i was wondering how to actually make something like that, it doesn't have to be complex just something simple that will be distinguishable as a zipper.
Message 9 of 10
TheCADWhisperer
Have you completed any other projects?
File>Export and then Attach your *.f3d attempt here.
Message 10 of 10
laughingcreek
He posted a model in message 2.  downloading that and stepping through the timeline would be a good place to start.
