Fusion 360 crashes when i try to edit sketches.
justo_urbina12
Message 1 of 22
justo_urbina12
Hello guys, since the last update Fusion 360 crashes when i try to edit sketches. Any suggestions, thanks for reading.
Replies (21)
Message 21 of 22
jeff_strater
I was able to add circles at the center at 7.25 and 6.00.  It just takes a long time:
Which brings us to the subject of complex sketches and performance.  In general, complex sketches in Fusion are not a good idea.  The performance will not be acceptable in a sketch of this complexity.   This looks like some kind of sprocket or gear.  You would be much better off to just model one of the teeth in a sketch, and use feature pattern to model the rest of the teeth.
Jeff
Jeff Strater
Engineering Director
Message 22 of 22
crh5055
Observer
Observer
Thanks.  An important lesson learned.  SVG files can import a lot of complexity that may need to be simplified.  In my case each tooth comprised hundreds of line segments.  But by using a spline and a couple of lines I was able to create a tooth face, then use mirror symmetry and circular patterning to create a complete gear with 60 teeth that does not crash and is accurate enough for my purpose.
