Fusion 360 crashes on startup
mando1373
mando1373
I Need help,
I love Autodesk 360 fusion but recently stopped working.
After using A360 with awesome results to model parts and produce cam files for my DIY CNC.
I found this Software to be the best thing I have ever used.
When I clicked on the start icon I got noting, and tried several times and ways to start the app.
I then tried to uninstall and reinstall the program, and got an unexpected Error!
[WinError 2] the system cannot find the file specified. Please attach the file
"C:\Users\armando\AppData\Local\Autodesk \autodesk.webdeploy.streamer.log"
to any problem reports before closing this dialog.
I have attached the said file .log
the specified file the system cannot find is "QtGui_Ad_4.dll"
or on previous attempts it was this missing file  "QtCore_Ad_4.dll"
I searched for theses files and I did find them under
C:\Users\armando\AppData\Local\Autodesk \webdeploy\production\e6bf3531fe9734dab4c4530aa6a4abd5cde03e6e
I don't understand why I can find them but the system cannot.
please help me resolve this issue and get back to making stuff.
thank you,
Armando
rishivadher
Hi Armando
Have done a full uninstall like is described in the fallowing post
http://forums.autodesk.com/t5/sketching-sculpting-modeling-and/installation-problem/m-p/4309647/high...
Best regards
mando1373
Hi Rishivadher
Thank you for your quick responce
I did try the uninstall method decribed in the post
and am stil getting the same unexpected error
Is there something else I can try?
Fyi my program maneger fails to uninstall Autodesk fusion 360
my system:
windows 8.1
Intel(R) Celeron(R) CPU J1800 @2.41GHz   2.41GHz
4.00 GB
64-bit Operating System, x64-based processer
thanks again
Armando
kris_berg
Hi @mando1373,
Can you provide more details on the uninstall failure?  After trying to uninstall does Fusion 360 still show up in "Add/Remove programs" ?
Thank you,
Kris Berg
Fusion 360 Development
Kris Berg
Senior Software Architect - Autodesk
svelez
Hello mando,
We install new versions of the software while old versions exist.  Old versions are not removed until the new version install completes successfully.
You can likely find the files because you are finding old versions of the files while the new versions are still missing.  That said, the new versions seem to be missing and I can't tell from the logs why.  Further, files for interacting with uninstall functionality are alos missing which are causing some of the other problems you are seeing.
At this point, it would probably be best to do a manual delete of the folder "%LOCALAPPDATA%\Autodesk\webdeploy"  before performing a re-install from the web link.
If there is any error reported during the delete (and before running the install), please reboot your machine and retry the delete operation.
Steven
mando1373
thank you Steven
it worked!
thanks
Armando
