Fusion 360 Basics Tutorial (August 2019)
Completely new to CAD, reasonably PC literate but elderly - so be sympathetic!
Bought this book but stuck on page 25 after creating the first diameter dimension of 1.2.   Next step says "create two more diameter dimensins as shown" - when I attempt to do so I get the error message "Adding this dimension will over-constrain the sketch. Choose OK to create a Driven Dimension."
I can't progress any further with the book and I'd appreciate any insights into what is wrong here?
g-andresen
A book from 2019 depicts the UI of that time and can lead to irritation, especially for beginners.
Please share* your design and describe which sketch elements are involved.
Then you will surely get hints based on the current UI.
*File > export > save as f3d on local device > attach to next post.
günther
Hi Guenther,
Thanks for the response - really frustrating not being able to progress.   I've attached the file as per your instructions.   One Diameter Dimension applied - but the two others give the error message as before.
Any insight much appreciated.
Charles
jhackney1972
There is nothing wrong with the method you dimensioned the sketch.  I can only guess what the tutorial you are using wanted you to do but in the Screencast I tried to show how you can use two additional diameter dimensions.
John Hackney, Retired
John,
Your response greatly appreciated.
I'm afraid I'm giving up with this publication just purchased from Amazon - I've now found other problems which I'm putting down to changes in the application since this book was published.   As an absolute beginner it is going to be a steep learning curve without having to cope with wrong step-by-step instructions !
Thanks again
Charles
jhackney1972
You can get some free training by using the Self-Paced Learning tutorials furnished with Fusion 360.  The screen capture shows you where to get started.  Remember, the Forum is here to help, there are lot of knowledgeable users willing to help with your questions.  Remember to always attach your model if the question concerns it directly.  This will speed up your replies.
