The Gurus have left you some excellent advice below.
I would suggest that your components are moving for a couple of reasons. Firstly you may be creating them
and then moving them to where you want them. If you fail to "Capture New Position" then they will snap back
to the original position. The other issue is that you are probably moving them into position but not using
Joints to keep them there. There is a thing called a Rigid Joint for joining components statically. If you use a
Joint then they shouldn't move unless it is a moveable joint like a Revolute or Slider Joint.
One common method I have seen in this Forum is to create components in one of two ways. You can create them
in an isolated way using the Origin for all of your Sketches and create and model them THEN use a joint to put
them where you want them. The other method is to build them IN PLACE where you want them. Using this method
they will not move around. I have used both but my personal preference is that if it needs to be in a specific place
then put it there with a joint.
In support of the Gurus - if you get a yellow or red error on the Timeline then FIX IT AS YOU GO. If you don't then
your model will probably (often certainly) fail if you try to make it or 3D print it. It is a bit like building a bridge
and you know there is a problem but it falls down before you can go back and fix it. If you had fixed it as soon
as you realised there was a problem, it will not fall down. You need a firm foundation when you model, the timeline
is your foundation.
Cheers
Andrew
