free form using triangle
marco.bresson
Message 1 of 19
marco.bresson
I would like to create a free form using triangles instead of rectangles (so, a sort of mesh). I can't find how to change this settings.
The goal here is to have flat surface when moving all the points in the 3d space 🙂
Replies (18)
Message 2 of 19
artemSIV
when creating a sketch, you can select a 3d sketch and arrange the points in space as you need
Message 3 of 19
TrippyLighting
Can you be a bit more specific as to what you are trying to model?
An image can speak a thousand words 🙂
Message 4 of 19
marco.bresson
thuis is the thing i want to model
the problem with 3d sketch is that i do not have the possibility to create a mesh with rectangular patern ^^'
Message 5 of 19
TrippyLighting
I am not exactly sure where you see a rectangular pattern in this object.
Message 6 of 19
marco.bresson
I do need a rectangular patern for the 3d sketch to build the "default parallelepiped" and then, moving all the point one by one !
The free form object was really helpful because it was really convenient exept that it uses 4 sided polygones, hence creating not flat surfaces 🙂
Message 7 of 19
artemSIV
here I show only the principle of construction
Message 8 of 19
marco.bresson
Wow.
Actually, i am impressed on how much time you spent helping a total stranger ! Thanks a lot ❤️
I will try this out tomorrow morning !
Have a great day (or night, if you are in Europe)
Message 9 of 19
marco.bresson
Hello !
I am having a little issue now ... I don't really know how to thicken my model. I mean, the thicken feature is not doing the job correctly because we can see some solid going outside the outter shape ! I hope it makes sense and as a picture worth a thousand words : (All surfaces outlined in red are facing the same direction)
I tried to stitch all the surfaces but it didn t worked either
Message 10 of 19
TrippyLighting
That screenshot looks like a mess 😉
Can you export your model as a .f3d and attach it to the next post?
Message 11 of 19
artemSIV
STITCH first, then SHELL operation
Message 12 of 19
marco.bresson
Here it is :
Message 13 of 19
marco.bresson
@artemSIV I already tried this but i have an error :
"the body could not be repaired after deleting faces. Try changing the selection, or use the Delete tool in the Patch Workspace to delete geometry without repairing the gap"
I don't really understand this error by the way ^^'
Message 14 of 19
artemSIV
Then let's see the file and write what wall thickness you want
Message 15 of 19
marco.bresson
Something about 2mm would be great 😄
Thanks you
Message 16 of 19
artemSIV
I did it in netfabb, and it’s much more convenient
Message 17 of 19
TrippyLighting
I think "convenient" is not how I'd describe it. This just cannot be done with thickening or shelling in Fusion 360. As the end result is likely to be 3D printed, using Netfabb or Meshixer is a good workaround.
Message 18 of 19
marco.bresson
Hello !
Thank you really much @artemSIV ! But the logiciel seems to be a paid software whereas fusion360 is free for student (which i am). Furthermore, it needs 64GB of RAM to run according to https://knowledge.autodesk.com/support/netfabb/learn-explore/caas/sfdcarticles/sfdcarticles/System-r....
But i do have meshmixer, i will try to use this software to do what i want as @TrippyLighting suggested !
Message 19 of 19
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hi, @marco.bresson,
Netfabb runs just fine with less. The 64 GB are a production-typical figure for projects with large amounts of parts, high triangle count (several ten millions and up), large slicing jobs, latticing, and so on.
Also, Netfabb still contains the free (no-cost) unlicensed mode, http://blogs.autodesk.com/netfabb/2016/10/18/netfabb-basic-is-now-just-netfabb/, and there's a free trial available (https://www.autodesk.com/products/netfabb/free-trial) that reverts to that same unlicensed mode when the trial expires. (You can also choose to never start the trial in the first place.)
Best regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online helpSystem requirementsKnowledge baseForumsHomepageYouTube
How to get Netfabb Basic: VideoHelpDownload
