Forms - Faces
Forms - Faces
sneddonmark
Forms - Faces
sneddonmark
Can I revert a form back to the original faces using modify?
TrippyLighting
The amount of feedback you'll receive is somewhat proportianal to how much information you share.
In other words, could you explain your problem in some more detail and perhaps provide a screenshot ?
sneddonmark
Sorry,
I'm new to the form. Here is a screen shot of the form I've created. I would like to go back to the faces I use to start this form. Mabe open the first version of the part?
Thank you,
Mark
sneddonmark
Oops for got attachment
sneddonmark
Sorry,
I'm new to the forum. Here is a screen shot of the form I've created. I would like to go back to the faces I use to start this form. Maybe open the first version of the part?
Thank you,
Mark
TrippyLighting
You can use the Undo arrow in Fusion 360, but that can get pretty tedious after every so many edits/operations.
Yes, you can use a previous version. In order to do so that older veraion must be promoted to hbe the first. I am not on my Fusion 360 station and can't recall exactly how to do it but the UI in the Data panel is fairly selfexplanatory.
