For everyone that wants a wrap function in Fusion....
PhilProcarioJr
Mentor Mentor
Message 1 of 117
PhilProcarioJr
Been working on easy ways to do this....more to come later....
Here is a sample model with results. I could have done any pattern or design just chose this because it has been asked for so many times.
This took about 2 or 3 min to do.
Phil Procario Jr.
Owner, Laser & CNC Creations
Replies (116)
Message 81 of 117
TrippyLighting
Nope. If you watch some some of Phil's screencasts in this thread you'll know why 😉
Message 82 of 117
PhilProcarioJr
@rocketmanthree
Well technically this is possible but each section would need to be done one by one thus making wrapping something to it very hard and in a lot of cases impossible. The best approach for stuff like that would be Blender or Maya then export as an obj and bring it in and convert it to a T-Spline then a solid.
Phil Procario Jr.
Message 83 of 117
hanskellner
I posted a wrap sketch to cylinder add-in that might also be helpful.  It's very basic but might be useful for some, especially if not using the sheet metal functionality.
This forum post has a couple of screencasts / comments about the add-in:
https://forums.autodesk.com/t5/design-validate-document/fusion-360-wrap-sketch-around-cylinder-and-e...
You may grab it from here: https://github.com/hanskellner/Fusion360WrapSketch
Cheers!
Hans Kellner
Senior Manager, Principal Engineer
Message 84 of 117
Noah_Katz
@hanskellner
Neither of those links seems to work...
Message 85 of 117
jeevesme
Confirmed.  The link does not work.
_________________________________________________________________________________________________________________________________________Forever yours,
Love,
Brian
PS. If this answered your question, please mark as answered so others do not read through the posts trying to figure out if it was answered.
Message 86 of 117
hanskellner
ARGH.  Stupid links...  and the post is locked and won't allow editing.
Ok, here are the correct links:
 @Noah_Katz@jeevesme
Hans Kellner
Message 87 of 117
isiah.davenport
Please show how you did this
Message 88 of 117
daniel_lyall
@isiah.davenport what part or post number.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 89 of 117
isiah.davenport
Post 35 of 88
Message 90 of 117
daniel_lyall
phils vid on post 65, is how you get the round then you unfold add the text extrude then refold done
Daniel Lyall
The Big Boss
Mach3 User
Message 91 of 117
LMD001
@isiah.davenport
As Daniel @daniel_lyall wrote, Phil @PhilProcarioJr made a video on how to do this, I only tried this from an example Phil posted, the ScreenCast came later but this workflow was his (very good) idea in the first place.
Kindest regards,
Ludo
Message 92 of 117
Have you shared a tutorial on how you are doing this process of wrapping your pattern around a cylinder? Can you share the link?
Message 93 of 117
TrippyLighting
@Anonymous There are several screencasts right in this thread!
Message 94 of 117
hi there   are thier any videos or step by step details  on how to do this  i am a beginner and want to make   my own (kor rollers) like this picture  could you post any l
@PhilProcarioJr wrote:
@jeevesme
More information...ok...everything you need to know to find out how I did this is on the Fusion preview forums.
@Anonymous made a post that shows the basis to create stuff like this. I already knew how to do the base for this before his post but it got me thinking since rarely use tools in the conventional ways I began testing "other" uses for the tools that are coming out soon and here we are. A very usable method to create geometry that was very hard or next to impossible before.
To answer your question yes I used the new sheet metal tools to achieve this completely in Fusion.
I hope this opens peoples minds to thinking outside the box to achieve their end goals instead of complaining about missing functionality all the time....
The Fusion team wanted to know our workflows to help them enhance the tools....I needed to be able to do stuff like this all the time as I rarely work on basic sheet metal designs. My designs create more advanced sheet metal forms so I needed to figure out a way to achieve this with the first round of tools they are going to be offering rather then complain about what is missing...
More to come....
Cheers
@jeevesme
More to come....
Cheers
Message 95 of 117
TrippyLighting
@Anonymous You guys have got to be kidding! There are several screencasts in this thread that show how o do this. Please have the curtesy to at least go through the thread and watch them, preferably after your done with all the tutorials in the Support and learning section.
It is perfectly fine to  ask questions, but it is disrespectful to those that help on the forum when you don't go through available material dan expect us to start with Adam and Eve.
Message 96 of 117
hanskellner
Yes, there are some screencasts in this thread and more over here:
https://forums.autodesk.com/t5/fusion-360-design-validate/fusion-360-wrap-sketch-around-cylinder-and...
Note, now that there's sheet metal support in Fusion 360, folks are using that for wrapping patterns.  See the following:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-121F6E58-0459-4552-85EF-319F44324AE6
http://www.instructables.com/id/Wrap-Text-Around-a-Cylinder-With-Fusion-360/
Hans Kellner
Message 97 of 117
the instuctable link u gave me was spot on thanks so much the only thing i couldnt get to work was the very last command to changeChain Faces to Extend Faces but i folded it back into a cylinder it seems to have worked
Message 98 of 117
hanskellner
Good to hear you were able to get it working.
Hans Kellner
Message 99 of 117
hi i know its not about this thread but i cant seem to find where to ask this question i finished a cookie cutter how can i change it to differnt sizes i have looked everywhere cant find answer ive tried the scale command but when i type in mm it goes way too big
Message 100 of 117
laughingcreek
Tacking a question onto the end of a years old topic, about something unrelated, is a terrible way of getting the answers to your question.  Go to the "design,validate & Document" section of the forum and post a new question there.
But first look at this recent thread and see if it helps
https://forums.autodesk.com/t5/fusion-360-design-validate/scale-while-maintaining-wall-thickness/td-...
