Font and svg text automatically convert into Arial font
Message 1 of 8
Hi !
It's been 7 days since I have been trying to use one font to extrude it , and here is what I tried :
- installing OTTF file font direclty on my MBP then in the TEXT module choosing the font but doesn't work , the Arial font shows up instead of the one I want ( MUSEO 700 )
- Using illustrator to write it in the font I want then export the SVG file into Fusion , but there the font is also converted into ARIAL ,
Note that :
- the font is properly imported into fusion because when I go into drawings sheets the font can be used to modify measurements and text font of the sheets .
Have anybody bypassed this or is it just a problem of mine ?
Configuration :
OSX Capitan MBP 15" i7
Last version of fusion
Thanks for the help !
Replies (7)
Message 2 of 8
daniel_lyall
Can you attach a model where this happens there are some problems with font's with Apple computers and fusion.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 8
Hi Daniel  ,
Thanks for your feedback
The screenshot that I have attached shows the problem that I have ,
The font selected is MUSEO while the font shows in the plane is ARIAL ,
Sonny
Message 4 of 8
daniel_lyall
@Anonymous A pick is not enough to nail this problem down, the fusion guys will need a model from you so they can look at it and see the issue you are haveing, They may not be able to reproduces this on there test computers at all I will pass you onto jeff.
@jeff_strater can you have a look at this please, there were some other guys that had a similar problem a few weeks ago.
Daniel Lyall
The Big Boss
Mach3 User
Message 5 of 8
Sure ,
here is the model
http://a360.co/2owAR1p
and the font attached both in ttf and otf
Hopefully we can found a solution for this !
Thanks Daniel !
Message 6 of 8
Hi ,
Any help ?
I'm still locked with this problem
Thanks !
Message 7 of 8
yqliu
Hi Sonny,
The problem here is the Fusion rendering engine can't recognize the font. One workaround is you can type the text in Illustrator, then create outlines in Illustrator and save the file as SVG. By doing this, the text will be converted into curves and can be imported into in Fusion correctly.
Richard
Message 8 of 8
markaudacity
Still having this problem in 2020. What exactly does "can't recognize the font" mean? A TTF is a TTF.
