- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi !
It's been 7 days since I have been trying to use one font to extrude it , and here is what I tried :
- installing OTTF file font direclty on my MBP then in the TEXT module choosing the font but doesn't work , the Arial font shows up instead of the one I want ( MUSEO 700 )
- Using illustrator to write it in the font I want then export the SVG file into Fusion , but there the font is also converted into ARIAL ,
Note that :
- the font is properly imported into fusion because when I go into drawings sheets the font can be used to modify measurements and text font of the sheets .
Have anybody bypassed this or is it just a problem of mine ?
Configuration :
OSX Capitan MBP 15" i7
Last version of fusion
Thanks for the help !
