Folders in projects
Folders in projects
Sandflo
Folders in projects
Sandflo
Hi Everybody!
I might have missed something, but is it possible to have folders in the the projects? Or have a project within a project would be even better?!
Lets say a start a new project called "customer" and ad i part in there, after a while the customer wants another part made, and i want to do it in the "customer" project, as a new project within the "customer" project.
Edit: i see now if i upload a folder it becomes a folder under the project, thats good
Thank you
__________________
Gigabyte P35 V3 , Windows 8.1, Sweden
jeff.pek
Yes -- you can have folders inside projects. You can create folders either from the A360 dashboard, or when you start an upload, and Change Destination, you can create a new folder.
There doesn't seem to be a direct way to do this within the Fusion Side Panel.
Jeff
Roman_Vesely
Hi Sandflo,
 you can create new Folder also directly within the Save document in Save As dialog:
To use "Folders" is much more comfortable, because you can DELETE them. Project could be only "Deactivated".
Regards
 Roman
Fusion QA team
Roman Vesely
Inventor - Principal QA Engineer
