Flattening Curved Surfaces
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I've got this design for a curved hood vent that I have made a couple of times now.
Each time I do, the sizes change a bit, and I haven't found a reliable way to draw this such that it doesn't break when I change the dimensions. Most of it I can handle, but the tough part is the curved skins.
I can (sometimes) convert them to sheet metal and create a flat pattern. But then I want to be able to nest all three pieces on to one sheet and cut together. However, inside the flat pattern, options are limited. I can export a dxf, but that seems to flatten the geometry, and I lose the mitered edges where the skins come together. Which is of course the main information I need.
I have been doing each part as its own setup in Manufacturing and running them individually. I was hoping to find a more reliable way to flatten these parts out so I can manipulate them with the rest of the design. Flat pattern seems to take you into a instance where the rest of the design is inaccessible. If anybody has found a better way to handle things like this, I would appreciate any insight. Thanks.
