Need Help with part design.
nikita.panasiuk.knm.2020
Message 1 of 8
I recently started taking a course on Fusion 360 and there, as a homework, I need to do one thing, but I'm confused by 4 parts on the sides, you only need to use the Shell, Draft, and Fillet tools. Of course, I can skip and not do it, but I'm wondering how to do it, because I tried to do it in different ways and nothing worked out for me.
Replies (7)
Message 2 of 8
jhackney1972
Attach the model of what you have done.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Message 3 of 8
TheCADWhisperer
@nikita.panasiuk.knm.2020 wrote:
...I tried to do it in different ways and nothing worked out for me. 
Attach your attempt(s) here.
Were you given any dimensions?
Given any section views?
Can you ask your instructor to join this discussion?
This doesn't seem like enough information/instruction was given to complete the assignment.
Message 4 of 8
Thank you very much for your diagram, it's more detailed and a little easier to work with, maybe I'll practice on your picture. I am taking this course on Coursera website "https://www.coursera.org/learn/mechanical-engineering-design-manufacturing/home/week/3" and unfortunately there is no online support or tutor, just regular videos and assignments. If it’s not difficult for you, can you advise some sources, after which you can go somewhere, at least as an assistant? I will be very grateful!
Message 5 of 8
TheCADWhisperer
Surely they gave you more than a picture to go by?
Message 6 of 8
No, only the condition itself and this picture.
Message 7 of 8
TheCADWhisperer
Hmm, well Attach your attempt here and then tomorrow I will Attach my attempt so that you can see how I modeled the geometry (I will have to edit a bit to get closer to the images).
Message 8 of 8
davebYYPCU
You would need at least a height dimension.
You could draft the top, but you and I would revolve it.
Maybe the inside flat panel?
Might help....
