Flatten Piece
Flatten Piece
hugo_gomesRVA54
Message 1 of 12
Flatten Piece
hugo_gomesRVA54
I've recovered this design from an old Inventor file.
Now I need to make those big sheets (marked in green) flatten to laser cut, any tips how to do it?
Replies (11)
Message 2 of 12
TrippyLighting
Those strips cannot be flattened with the native tools in Fusion. The sheet metal functionality only works on developable geometry.
Someone @TheCADWhisperer or @jhackney1972 or @Warmingup1953 ) will post a workaround that involves Autodesk Meshmixer.
Message 3 of 12
hugo_gomesRVA54
Yes that part of the developed geometry I'm aware, we can have it cuted in more than one part to overcome that problem.
The question now is that as it is I can't do nothing with the drawing.
Message 4 of 12
TrippyLighting
I don't think you understood what I wrote!
I posted a link to a Wikipedia article that explains what he term "developable surface" means. I suggest you follow the link and read that article 😉
Message 5 of 12
billbedford
Going back some 50 years, when I briefly worked in a shipyard drawing office, we produced tables of offsets, ie x and y values along a curve, which allowed the yard to make curved steel sheets from the flat paper drawings the DO produced.
I'm sure you could be do this in reverse for your bell.
Message 6 of 12
kacper.suchomski
This can be done in Inventor using the Unwrap tool.
Kacper Suchomski
Message 7 of 12
hugo_gomesRVA54
That's where the original elements was designed but we don't have inventor licenses anymore.
Message 8 of 12
hugo_gomesRVA54
No no I think got it! Since there's a curve on the Y axis and another on the X trying to flatten the surface may not be possible because when you flatten the Y axis the X won't "know" how to react because it will probably creat bumps.
Message 9 of 12
TrippyLighting
Yep. Correct.
The flattening you need can be done in inventor, but unfortunately still not directly in Fusion.
We've been asking for this for a long, long time!!!
Message 10 of 12
Warmingup1953
Will you simply laser cut and install flat as cut without forming to the varying radii?
Message 11 of 12
TheCADWhisperer
@hugo_gomesRVA54
Remove all of the beads.
You need only one panel. (They are all identical.)
You can use free Autodesk Meshmixer Unwrap tool to flatten the panel.
Message 12 of 12
Warmingup1953
Here's my go via Meshmixer. E&OE!
