Split body partial reconnect?
bmg88stang
bmg88stang
Can I reconnect a body that I have split in half at only two faces? I would like the highlighted faces to be reconnected leaving the other two split. Is there a different way to go about this design to achieve this?
wersy
You could extrude the face to body.
bmg88stang
Apparently I should have mentioned the two bodies are actually components. This works on bodys perfectly. Is there a way to connect components in this way or can I convert the components back to bodies?
bmg88stang
I deleted the component commands from the timeline and was able to extrude the face to body. Thanks
wersy
So if you have no further questions, please mark it as solved.
