You can convert to a sheet metal part but you do need to make some edits to the part. First thing I did was enable history, then convert all bodies to components. Then the most important is you need a constant wall section so you need to add a fillet to the back corner. I did this with a sketch so no need to calculate anything but you could just use the fillet tool. Next problem I found was I needed to remove the hole and counterbore.
After these mods, convert to a sheet metal part and create a flat pattern.
File's attached for reference. Note the part imported as 5mm thick, I guess the units were not set in the DWG so it imported in CM so instead of 0.5" you get 5mm!
Mark
Mark Hughes
Owner, Hughes Tooling
