flatten a dwg
flatten a dwg
glennS4R84
Message 1 of 12
flatten a dwg
glennS4R84
super new to fusion 360 here.  customer sent me a dwg of a part, I'd like to be able to flatten the part so we can cut on plasma but i have no idea where to start...
Replies (11)
Message 2 of 12
Warmingup1953
It looks more like a machine from solid rather than plasma cut?Screen Shot 2023-02-23 at 3.51.56 am.png
Message 3 of 12
jhackney1972
Your customer probably sent you the wrong DWG.  This is a machine part and there is no way to flatten it and I doubt it can be cut out with a laser.  You can use Fusion 360 to probably create toolpaths to machine it.
John Hackney, Retired
Message 4 of 12
Warmingup1953
...0r do you just want to "Extract" 2D parts?Screen Shot 2023-02-23 at 4.07.16 am.png
Message 5 of 12
glennS4R84
yes, it was originally made out of angle iron.  i was hoping to burn the profile out of 1/2" plate, bend it and add the machined features.  was hoping to 'flatten' the part without having to redraw but thinking that's not an option..
Message 6 of 12
glennS4R84
that could work possibly, not sure how to calculate how much material i'd need to add to bend the part after though?
Message 7 of 12
Warmingup1953
You can easily use the bodies to create sketches 2D and start again but 1/2" is going to bend up a long way from the offsets.
Message 8 of 12
Warmingup1953
even in 3mm it'sScreen Shot 2023-02-23 at 4.28.10 am.png going to be hard unless you override Bend radii and k
Message 9 of 12
glennS4R84
Fair enough..stick with the angle iron I guess. Do some other parts similar so shouldn't be too tuff.
Message 10 of 12
HughesTooling
You can convert to a sheet metal part but you do need to make some edits to the part. First thing I did was enable history, then convert all bodies to components. Then the most important is you need a constant wall section so you need to add a fillet to the back corner. I did this with a sketch so no need to calculate anything but you could just use the fillet tool. Next problem I found was I needed to remove the hole and counterbore.
After these mods, convert to a sheet metal part and create a flat pattern.
File's attached for reference. Note the part imported as 5mm thick, I guess the units were not set in the DWG so it imported in CM so instead of 0.5" you get 5mm!
Mark
Mark Hughes
Owner, Hughes Tooling
Message 11 of 12
HughesTooling
@glennS4R84  Here's an update version scaled up by 2.54 and converted to inches. Now 0.5" thick.
Mark Hughes
Message 12 of 12
jhackney1972
@glennS4R84, you need to read this Forum article and re-mark your Forum post as to the post that answered, or helped to answer, your question.
