Flatten a curved surface.
Message 1 of 11
I can't figure this one out! I thought the sheet metal workspace would save me but no luck. All I need to do is flatten this curve so I can laser cut it....
Any thoughts?
Thanks!
Replies (10)
Message 2 of 11
TheCADWhisperer
What happened to our sketch(es) for creating the geometry?
Message 3 of 11
This .stp file was given to me by a Rhino using co-worker. No sketch is available. I guess there's a simple was to do it in Rhino but I need to be able to do these in Fusion long term.
Message 4 of 11
TheCADWhisperer
@Anonymous wrote:
This .stp file … ... but I need to be able to do these in Fusion long term.
Hmm, it is easy to get a Flat Pattern with a specialized technique (image), but I am holding onto the technique details until after AU.
Just some encouragement with a bit of logical thought - it can be done and is easy to convert your imported STEP to sheet metal flat pattern.
Message 5 of 11
HughesTooling
@TheCADWhisperer I've come up with a way of doing this, think it might be how you've demonstrated before. I can get a flat pattern OK but if I use Unfold Fusion crashes, did you try unfold? Not sure about uploading the design, don't want to give your secrets away although I might have done it differently.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 11
TheCADWhisperer
Hmmm, Unfold does present an issue in this case even though Flat Pattern worked.
Message 7 of 11
Yeah, I'm hitting nothing but walls here. Might need to cut bait as I've already burnt too much time trying to solve this.
Message 8 of 11
TheCADWhisperer
Have you designed a Sheet Metal part in Fusion before?
Are you familiar with the Four Rules of Sheet Metal?
Message 9 of 11
Just a simple box which I can unfold but having someone gave me a curved body as a .stp file and no sketch is proving difficult.
Message 10 of 11
TheCADWhisperer
I'll see if I can ping Ron Jones for you and perhaps he can demonstrate the technique for converting imported STEP to Fusion Sheet Metal.
Message 11 of 11
tommVS2MB
I think if you put a sketch on the flat end and extrude as join you will be able to unfold the curved portion. If you want an example look at the YouTube video where a cylinder is opened flat,
I am sorry I cannot test this, and I tried.  The release I received today flopped so many ways I gave-up. I have reported my problems in another posting.
Tom Meyers
