Slide Joint position issue
nirmalmehta
nirmalmehta
Hello Fusion people,
I have a joint issue in my fusion.
I have designed a smartphone with a profile switch. I am trying make a sliding joint between switch and the main body of the phone with some out of like 0.2mm from main body (it is a body not component). when i select to edit the feature, it shows as I want but when I render the switch flushes completely with the body.
Have attached a screenshot for reference (the one with numbers is how I want). Kindly help as I need to present the final renders to my client
chrisplyler
You need to make a Joint between two Components, not Bodies. Then once you make the Joint, you can edit it's resting position and travel limits.
