Flat Pattern Won't Fully Unfold
4 REPLIES 4
designoX9L6N
212 Views, 4 Replies
Hi, I've got a sheet metal part where the flat pattern doesn't fully unfold. Most of it unfolds, but some bends don't.
I have made a similar design dozens of times without problem literally dozens of times - this is my job at my work - and for some reason when making the part, originally it would not allow me to extrude along a path with the flange tool as I usually do. I had to use the sweep tool. I don't know if this has anything to do with it though.
I'm stuck; I don't know how to proceed. Any thoughts?
Thanks so much,
Mike
4 REPLIES 4
without your model, it' just a guessing game (you could export and attach your .f3d file for better help)
first guess, is the circled edge filleted, or is it a hard edge?  looks like a hard edge in the pic-
Hi laughing creek, many thanks for your insights.
I'm not sure what you mean by a "hard edge" - this came about from a sweep.
As I said I've made this shape many times, usually just using the flange tool and a path, but it won't work on this file for some reason. I had to use the sweep.
I am attaching the file here. Thank you to you, or anyone else, who may have insights into what's going wrong here.
Thanks so much,
Mike
g-andresen
in reply to: designoX9L6N
it is as @laughingcreek suspected
> add fillets
günther
designoX9L6N
günther - many thanks! That was SO helpful! I had tried adding a fillet but had only done it on one side.
Thank you again, what a great community!
All my best,
Mike
Technology Administrators
