Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Offset series of Lines and Curves..?
8 REPLIES 8
Message 1 of 9
mail8YLTP
304 Views, 8 Replies
I am trying to work out the best way to create a 3D printed spring that is extruded from a flat 2D series of S shapes. I started by creating 5 circles and then a line tangential to each one, then cut the inner curves. The problem started when I tried to select all the lines and offset them to 0.25mm one both sides of the line. I would only allow me to select 2 lines and a curve at a time then finally cap the ends so that I could extrude it. Is there a way of connecting sketch nodes to make one polyline? It was very long winded selecting each section and offsetting on each side if the line. I would assume there must be an easier way? My picture shows my methodology and at the resultant shape.
8 REPLIES 8
Message 2 of 9
g-andresen
in reply to: mail8YLTP
Please share the Basic file
günther
Message 3 of 9
jeff_strater
I think the problem is these white dots in your center set of curves:
Those indicate that the lines and arcs are not connected.  Offset will chain connected curves, but will stop if it does not find a connected curve.  Use the Coincident constraint to connect them.
Jeff Strater
Engineering Director
Message 4 of 9
mail8YLTP
in reply to: jeff_strater
Yep thanks for that, I should have known better. I put tangential constraints on each line and that sorted it.
Message 5 of 9
laughingcreek
sometimes it's easier to use simpler sketches.  for instance from this sketch-
you can get this-
most of the work is done in the modeling space.
Message 6 of 9
mail8YLTP
in reply to: laughingcreek
That looks interesting, can you attach your file please so I can work it out easier...
Message 7 of 9
etfrench
Thin extrude would be easier than using offsets:
This was started with a slot.  Dimensions were added. One arc deleted and one added.  To complete the spring use a rectangular pattern.
ETFrench
Message 8 of 9
laughingcreek
here you go.  I meant to attach it before.  this was just a first go, I would likely work out something a bit more elegant if I put some thought into it.
Message 9 of 9
mail8YLTP
Thank you...
